success
It took me longer to write this (crappy computer) than to do this procedure.
Fully charged battery.
Engage parking brake.
Remove driver's seat..place on to back seat.
Disconnect battery.
Shine lights on clutch pedal adjuster ass.
Lay on back.
Fuse panel can be tilted to ease with this ordeal.
Remove shield... a pair of 8 mm. screws mounted on the side of the shield.
NOTE when on YOUR BACK the screws are to be removed from the left side of the shield. Look for a pair of protruding screws on the right side of the shield to get an idea to where to place the socket
By pulling up on the clutch pedal it releases the "hold" on the adjuster, allowing it to spring towards your head or to be push up to it's furthest most upwardly position.
Pull up on pedal...push on adjuster with a screwdriver.. let the pedal recede about an inch ..(idea is to not let the "hold" to release)
Place end of cable into adjuster
Place other end of cable onto transmission "arm"
Pull up on pedal & step on it a few times... repeat ... again
Viola there it is.
If your **** you can replace the shield.
Slap the rest of the s**t back on.
BTW got mine at brand "P" autoparts store for $20... LUK brand made in Italy.
