black93sho
The accessory belt on my 93 ATX came off las night. It looks old and its shredded. When I went to check the pulleys the water pump pulley wobbles. Is it just loose or what?
black93sho said:The accessory belt on my 93 ATX came off las night. It looks old and its shredded. When I went to check the pulleys the water pump pulley wobbles. Is it just loose or what?
Ishodu said:Does the shaft move up and down wobble or the pulley wobble on the shaft? It could be loose too. Just check the bolts.
black93sho said:Yes it does wobble and move up and down. I ordered a new pump today but I should definently check That first. It would be a big waste of time to replace it if its just loose. How do I hold it in place to tighten the bolts?
