acceleration
93SHO
Littleton, CO
Try coming on the throttle a little easier. I find my car noticably quicker if I progressively apply the throttle, rather than just floor it right off the bat.
jthomas68
Area 51
It could be you have a vacuum leak causing the secondries to stay open.If you open the hood and rev the engine to 5k,you should see the butterfly shaft move.
edogg23
Buckley, WA
Do you live in orlando or is that your name?
<small>[ February 21, 2002, 04:47 PM: Message edited by: edogg23 ]</small>
93SHO:
That sounds like the throttle tip-in problem from a bad throttle position sensor. It behaves the came as a carburetor when the accelerator pump quits working.
