96lt1
Likes to cut
Hey everyone,
I am currently working on a 93mtx that I picked up not running. I have gotten it running and one by one I have been getting the issues on the car straightened out. I am down to two things.
First is the biggie. When you drive the car normally it runs absolutely perfect but if you go to WOT it will cut out for a second and then come back with 100 percent power. I tried unplugging and changing the maf with no luck, did a basic tuneup, nothing.
Last night I was messing with it and found a tps I had laying around. I swapped it out and drove it, no change.
So I decided to just unplug it and see what happends. I started to drive it, from idle to 2500rpms it would barely even move, but once I hit 2500rpms it shot off like a scalded dog. I found as I drove it some more that as long as I was above 2500rpms the hesitation I had at WOT was completely gone.
So I ask, is the TPS the culprit? If not anyone have any ideas?
The second issue I think may be related to the first, it is that in order for the car to start I have to hold the gas pedal to the floor. Once it fires it will smoke for a minute and then is ok. I am hoping solving the first issue may help with the second.
Any info or help would be greatly appreciated!
Thanx,
Sean
Thanx,
Sean
