peglegtom
The new AC compressor clutch drive did not solve my problem with its intermittent operation. I also replaced the AC clutch relay and diode in the power distribution panel, even though this was done previously. I now feel that the problem is in the wiring between the relay and AC clutch (or possibly prior to the relay). However, I cannot find a wiring diagram for the AC on the web to assist me in troubleshooting this problem. Does anyone have one or has information on where I can find one on the web?
The AC works when the engine is first started and cold, however, once it warms up, it shuts down. It typically will not work if the car is re-started when warm. The problem became worse after the clutch was replaced, suggesting that the problem is somewhere in the vicinity of the compressor. I believe that an almost broken wire is the problem, which provides continuity when cold, but not when hot.
Thanks in advance!
Thanks in advance!
