peglegtom
Having an issue with the AC on my 99 SHO. Sometimes it will work normally, blowing cold air. Other times, it doesn't work, and no cold air is produced. This can happen while driving the car (the AC may be working fine, then shut off, then start again). Other times, it won't work after re-starting the car, even though it worked fine prior to stopping. Of course, it always seems to stop working when I'm driving a long distance in hot weather (this is not an accurate observation, just a snide comment).
The blower motor continues to run and blow air under either circumstance, it's just hot (ambient, not hot from the heater) or cold. Changing the settings or shutting down and re-starting the AC doesn't seem to make any difference.
Any help would be appreciated.
Thanks!
Tom
Thanks!
Tom
