Mark in PDX
Hi Guys,
My 89 with the automatic air system (red one doesn't have it and other black one has no AC yet)... has been refilled with 'HotShot' R-414.
Which is supposed to act like R-12, it is oil compatible & compressor compatible...
My question is, has anyone else ever tried this? Can you tell me about your experience?
Here is why I ask...
I have replaced just about every 'o' ring and tube/hose for my AC system in the process because I have lost the compressor, hi-pressure hose, accumulator hose.. and the manifold pressure hose that is a hard line at the compressor. Note that some of these were damaged due to my car being rear ended and the engine moved slightly and bent the manifold hi-pressure line off the compressor.. which may have been what damaged my compressor.. dunno... ANYWAY-- My system appears to hold a vacuum for about an hour -30 ?? (forget what you measure vacuum in)milibars?
Anyway, we have filled the system, but when putting it at 35psi (?) on the low side, it seems to >slowly< be leaking out somewhere. We have used a sniffer and spent an hour going over all the connections, inside & outside the car and couldn't find a leak, but over about 2 weeks, my compressor slowly starts getting more active and the air slowly gets less cold, we topped it off 1x to just keep it going for now, but anyone have suggestions on how to find this stupid leak? I had a ford dealership put in the compressor and they were >SUPPOSED< to check the system for leaks, but didn't!.. I haven't decided if I should just take it back and say, Hey, when you put the compressor on you didn't leak test it.. Please at least put dye in the system for me or something.. and see if they will.. I have a buddy in our sho club who has the lights to find dye.. but the guy actually helping me with the AC doesn't use dye to find holes.
Suggestions (prayers!! I have sunk a BUNCH of money into the AC because I don't like driving a car with a system broken...sigh
Mark
Mark
I guess I must've adapted to breathing pure CO2 down in these lowlands. I guess I better not climb to that helium layer up in the mountains!
