AC Delete Horsepowa Gain
93 SHO Tuner
West Coast Canada
I got my SHO without an AC compressor as the previous owner said it siezed and they had their mechanic bypass it.
What if any extra hp would this free up? 3-5hp maybe?
Joe_SHO
ND
As far as I know when the AC is off it doesn't drain any hp. The main thing is the weight.
Art5
white plains, NY
I didn't put my car on a dyno after I did that with one of my cars, but, i felt a lot of power gain with MAF,FIdanza and no A/C at the same time.
SHObill
'The Collector'
Rochester MI-48307Detroit
is the AC comp. still in place?? its very important for it to be there as it is a support for the front MotorMount.
You will snap the frt engine support brkt without it!
-there is no gain in HP to remove AC except the weight if you remove everything.
93rev2sev
Hockeytown
Bill right.
Unless the AC is running the pulley is no more than an idler. Nothing to be gained.
hawkeye18
Sorta cares
Norfolk, VA
Doesn't the compressor cut out under WOT anyway?
Yessir, it sure does. Gutting the compressor isn't really what gets you the biggest bang. Granted, yeah, it's like 15-20 pounds or whatever, but if you gut the compressor you might as well remove the condenser, the accumulator/dryer, and alllllllllllll the tubing and hoses that run all inbetween everything.
So not only does that make the engine bay look a lot cleaner, it ends up being about 40 pounds, all of it waaaay up front, which helps the weight balance out a bit. And there's more room to get to stuff!
raff18
frosty95mtx
ontario canada
^ i removed everything in the engine bay todo with the a/c and gutted the comp, man oh man it looks so much better in there.
and my new belt was about 2.5" inchs shorter
sho2see
sho2see
Baltimore, MD
I did this to my old 93 atx n took 2 pulleys out n ran a shorter belt, yea def. Some gain
i dont know wih the mtx since it runs 2 belts
SeanMc
NoMoSHO
I will never remove my a/c. In the summer, there is just something about cruising at 75mph with the air on. Oh right, it feels good. I lived without a/c the first 3 years I had the car. I'm glad I got it fixed.
