ac compressor?
sphinx311
chitown
i have a 93 atx and the clutch has gone bad, it is making noise constantly and causing bad vibrations too. my question is will an ac compressor off of any sho work or are they diffrent between atx/mtx and gen 1 or 2.
THANKS IN ADVANCE!!!
sphinx311
chitown
yeah i know but the compressor is probably junk to and i can probably get a used one for cheaper than a new clutch...
roswell998
Atlanta, Georgia
projectSHO89 said:
All 89-94 SHOs use the same compressor. The 95 is different for whatever reason.
Steve
I know the 93 SHO is R12 (the SLO was R134). At what point on the SHO did they switch to R134 and did they use a different compressor at that time?
stevetatro
Cincinnati, Ohio
Why would you assume the compressor was junk? At 170k miles I thought my compressor was bad. Tore the car apart, installed a brand spankin' new one. After inspecting the compressor it was fine, just the clutch had kicked the proverbial bucket.
If you buy a used compressor how do you know how long it will last? It will no doubt have an old clutch on it and you could be in the same boat in no time. What if it has the wrong oil in it? How do you know if it has the proper amount of oil in it? Are you going to do a full system recovery on your entire system?
I vote for a new clutch. That way if your compressor does go bye-bye you can buy a used one and have a nice new clutch to transfer to it!
sphinx311
chitown
well the car has 150k and it is making a lot of noise, the compressor itself doesn't kick on or off, which could be a lack of r12, but im pretty sure it is empty and has been that way for a while. so i assumed it would be safer to put in a lower mileage compressor and clutch and recharge the system all at once...
rangerj
Brunswick, Ohio
There are two refrigerants authorized for use in automobiles in the USA, R-12 and R-134a. They both work equally well. The A/C components, that is the Compressor, condenser, evaporator, filter dryer (acumulator /dryer in Fords), expansion valve or in Fords an oriface tube, and the high and low pressure lines and manifolds, are not specific to either of the refrigerants.
The two differences that must be considered are the seals ("O" rings), and the oil. Some properties of R-134a necessitate seals made of a different material than those used for R-12. Otherwise the "system" works exactly the same with either refrigerant. But, the refrigerants cannot be mixed and neither can the oils. You either use one or the other, but the correct seals and the correct oil must be used for the refrigerant you use.
If you want to save money then convert your R-12 to R-134a. Otherwise the R-12 refrigerant could cost you as much as every thing you need to do to convert to R-134a. R-12 is near $200 per pound in some places and it will get more expensive as it becomes rarer. It is no longer legally made in the US and cannot be legally imported. There are a few purported substitutes being sold, but beware they are EXTREMELY dangerous to use. They are explosive. rangerj
sphinx311
chitown
thanks 134a is the plan----so is it definite that the compressors are the same for atx mtx from 89-93???
