revhardSHO
Strange problem. With the climate control on and set to any setting (including 90* heat) the AC compressor will short cycle for about 4-5 seconds then disengauge for about 25-30 seconds and then repeat the above. The compressor sounds normal but doesnt stay on long enough for me to see if the AC system is working. Strange part about it is it will cycle like this even if I have the heat blasting. Im sure its terrible for the ac clutch so I would like to get it fixed ASAP. For now I just leave the climate control off. Im thinking the system is running low on refridgerant, but thats just an uneducated guess. Any brands to stay away from or is it all good? Should I run a bottle of stop leak in there too? Why on earth is the compressor cycling when the heat is on??? Any thoughts?
thanks!
Silas
thanks!
Silas
