AC Compressor Pully Bearing replacement
SolidState
No Mo SHO
Toronto, Ontario, Canada
the 91 started clacking really loud this moring....
had a look inside and the clutch is shreded....no biggie, but the pully seems to have bearing damage from it.
Do I replace the whole pully, or just the bearing? what is the procedure here?
rangerj
Brunswick, Ohio
SS,
The bearing is available for 89 through 92 as a replacement item (maybe some additional years by now). Got to a parts store, or a bearing distributor.
You gently remove the retainer spring on the backside of the pulley. Then you press out the old, and press in the new.
I'll see if I can find the bearing number for you. I have my reciept, somewhere.
Louis? Can you help here? rangerj
