ABS speed sensors for gen 3 subframe swap
black92
Wisconsin
I've completed the gen 3 subframe swap in the 90 SHO. I reinstalled the original speed sensors which were working prior to the swap. Since the swap the ABS has not worked and the system gives me codes for the front speed sensors.
Kelvin (K-Dawg) I saw in a prior post that you installed v8 speed sensors. Is this required?
Everybody else, what are you using?
Adam.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
what knucks are you using? maybe you should shim the up or somthing is misalined? It could be a number of things.
Adam.
black92
Wisconsin
I will attempt to get pictures after work today.
One thing I know is that the sensors are on the front of the knuckle for the gen 1 & 2. Its now on the rear for the gen 3.
SinisterSHO
Rust free
630, IL
I dont know why it would really matter since the axles are the same. Unless they were damaged internally when they were removed. FWIW, my g3 subframe was using g3 sensors also.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Which one is it? 93, or 92? FWIW the G3 sensors I used didn't work in my 92. Looking into my service manual, and testing with an ohm meter, produced a reading that I couldn't use. So there must be a few differeneces. ?
zak
east of Hartford
I used Gen III sensors in my 95's Gen III subframe conversion, had NESHO do the welding as they have a nice 3D jig for properly locating all the mounts.
black92
Wisconsin
seems like gen 3 sensors are the ones to use.
I'm guessing its the mounting location of the sensor?
SinisterSHO
Rust free
630, IL
i would find a way to test the ones you have on the car and see if they're even good. The gen 3 sensors plug into the gen 2 body harness, so I dont really see how they could be different. Just doesn't seem to make sense to me.
