abs sensor location on upgraded brakes
19sho90
Colorado
I bought the brake system off Tim. impt in e process of installing them. where do the abs sensor go? do i use it? its the the 12.2 the kit.
kevinspann
Don't take my advice.
Richmond VA
Not sure how those are set up....shouldn't it just go in the stock location? Unless it's been removed for some reason?
yeah, since the abs sensor is on the knuckle, not on the brakes.
K-Dawg
Treasure Coast, FL
Those kits use modified knuckles, but I don't see how the ABS mounting tab would be affected. Me thinks you have 89 knuckles.
19sho90
Colorado
Cool thakns guys. Ill roll without it till i hear from Tim. Also i meant wrong section for this post!
