SHOBrad
A friend of mine is having an odd problem with his abs: One day the light came on and he immediately had it checked. The codes were C1175 (left rear speed sensor) and C1236 (left rear speed sensor no input). He had the sensor and ring replaced and the abs works perfectly fine but the light continues to stay on. He also had the connector under he battery looked at with no luck. Is there some-kind of latch for the light that has to be reset once a problem is fixed? Any advice would be appreciated!
Thanks,
Brad
P.S. The car is also throwing a P1236 engine code but I really don't think there would be a correlation.
Thanks,
Brad
