Check for spark. Put a screwdriver in a spark plug wire, hold it about a half inch from a ground source, and have a friend crank the battery. If you have good spark, make sure there are no obstructions in the air path. If no obstructions are found, make sure you are getting fuel. Disconnect a fuel line and check to see if fuel comes out when you turn the key on. If so, check for compression. When replacing a timing belt on most vehicles, you have to back the timing belt off from the tensioner, then torque it down until it lines up or some weird shit like that. It's explained in any chiltons or helms manual. I'm sure that's your problem. Are you sure you the pistons didn't slap the valves? You should have about 130 psi of compression for each cylinder. Good luck!
<small>[ September 14, 2003, 08:37 PM: Message edited by: jasonty ]</small>
