...A pair of '90's
SV&HOdan
Pittsburgh PA USA
...parting out a set of nearly identical twins: 1990 electric red SHOs, both with black interiors, one full leather
and one leather cloth. Both cars are stock and complete as of now. One has typical PA rust blight and the other
is rust free from New Mexico. Bad motor in the New Mexico car.
sperold
Last to Know
Hi Dan.
Still interested in a non VAPS rack when you have one available.
Keep me in mind when you get some time.
Keith Hutchings
North Chatham
Keith Hutchings
North Chatham
I also need the unit which changes the heat, its in the dash board and air condition condenser.
let me talk to my mechanic but I bet I could use crank sensor, the item in the dash and the air condition condenser.
Thanks Keith 508-237-1082
TornadoHands
Chicago
Also need a crank sensor. You said one had a bad motor, did the sensor get soaked or do you think it's good?
SV&HOdan
Pittsburgh PA USA
I dont think the sensor got soaked...car ran but knocked. I may be able to
get a loose one from a friend of mine. It may be a day or two til I get back
to you. If I can get this one, it'd be $45 shipped. Even the used ones are
getting scarce.
thanks,
dan 412 539 6294
ps: did you sign up for the group buy?
zoomlater
Seattle, WA
If your water pump isn't leaking, I would expect your crank sensor to have many more miles left on it. I would reuse it unless you can track down a brand new one. Just change the pump and seal to extend the life of the crank sensor.
TornadoHands
Chicago
I've got a bit of a coolant leak, somewhere - I haven't been able to find it yet. I'm pulling together OEM parts for a 60k this winter - I'll do it first thing next summer - and it'd be nice to be able to replace it if the pump's been leaking on it.
If not I'll return it to the community when someone needs it. :)
SV&HOdan
Pittsburgh PA USA
50/50 rear seats are scorched at the top; not sure about the full leather
set. I think they were pretty bad but I'll check next time I'm out where the
cars are stored.
1stGenTX
TEXAS
I need an 89-91 front bumper. No cover needed, just impact plastic behind cover.
