brnxbmrfn
ok so i had a coolant leak. it was from that little 2 inch hose that goes between the t-stat housing and the other housing on the other head. i tore everything apart replaced the hose and i think i got the coolant leak licked. i say think because i cant start it to pressurize the system. i have check engine codes 15 and 26. i didnt like the looks of the code 15 especially since it said bad pcm. i accidentally cranked the car when i had everything torn apart. the TPS MAF and all the coolant sensors disconnected. i have no spark. and everything is reconnected. i really home its not a bad pcm. any thoughts??
