A Horn-like noise......
DigDeez
Chicago
From time to time, I hear this horn-like sounding noise coming from the wheel area mostly from the left/front side. If I take off slowly, after starting the car, I can hear this noise. The noise seems coincide with the wheel rotations, but it disappears as when there is more wheel revolutions.
Can this be a lubrication issue? Any ideas would be a starting point for me!
Thanks!
DigDeez
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Might be as simple as the pads dragging on the rotors. Try applying the brakes very lightly and see if the noise goes away/changes. Check for debris between the dust shield and rotor.
Perry
Val
Las Vegas, NV
One of the brake pins is lose and this way ur pads are crooked and are not using the whole surface area on the rotor, just take ur caliper off and put it back together.
