a few things i found while doing my hood pins
ilikepoultry
6th motor SHO
Pewaukee, WI
what is this for?
IM000187
IM000186
IM000185
do these run to the foglights?
my foglights had three spades... is there a chunk of wire or something that runs between this connector and the foglights?
i found one on both sides connected to the light closest to the grille on both sides
they were both jammed down into the frame... and i remember not seeing wires when i had the foglights installed
IM000183
IM000184
sorry if i post too many pics, but if i don't have anything to connect to those, why have them?
plus i'm trying to learn what everything is and dan couldn't help... i'd call others, but i don't know anyone's number - my contact sheet ran off with my sanity
P.S. the only reason i put in hood pins was because my hood tried to seperate on me yesterday while running errands... i couldn't go any faster than 15 mph before it started to come up... now it doesn't even wiggle... problem solved - except for these connectors and sensors
whiteman_01
Well-Known Member
Hastings, MN
The first thing is the sensor for the outside temp on the eatc. The second is the wire for the fog lights, and yes, there is another harness that goes between there and the light.
ilikepoultry
6th motor SHO
Pewaukee, WI
no, the temp wire's i'd keep
the foglight wires keep trying to jimmy their way out of their spots
so i was hoping to just cut them and end their jimmying
