A few problems
SHOguy 92
Duluth, MN
Alright well I just about got my 91 together, tried firing her up today and it just turns over. So I'm taking a look over, I found 2 things not connected in the back of the motor to the pass side of the exhaust manifold, hopefully someone can tell me if they aren't suppose to be or if they are and where...
That right connection kinda looks like the O2 plug, I haven't tried the O2 in it because It's already connected here..
So any help on figuring them out would be great. Also will a SHO run with the front o2 unplugged? The part of the wiring harness that connects to the front o2 is missing, the 3 wires stick out by the alt that are suppose to run down. I tried using a taurus O2 and matching the colors but they don't match. The car just spins over freely atm, so any help would be appriciated :thumb:
SHO Bandit
West Virginia
I think they go to plugs that are located on a black metal bracket. The bracket is bolted to the intake on the passenger side with the intake support bolt. There are like four plugs hooked onto the bracket, the two in your picture if I recall are under the other two.
If this does not make any sense I can try to take a pic for you (my 94 ATX has its intake off right now).
SHOguy 92
Duluth, MN
Yeah I got the upper 4 connected and those 2 are under it, but I can't see any possible place for them to connect, Im going to go take a look at the car right now and see if i can figure it out. See if I can get the plugs that are attached to the metal bracket out of the way.
SHOguy 92
Duluth, MN
Went and took a look and found the connections, they are under the 4 bigger connections on that back bracket. And the wires go up, couldnt find nothing because I was looking underneath, thanks for the help :salute:
BTW, it's now running :D Tomorrow it'll be on the road.
