A Couple Common Oil Issue Questions.
SinglePushRod
Portland, OR
With oil in the spark plug wells, does this generally mean that a valve cover gasket needs to be replaced?
Also, Where is the best place to buy cam seals, crank seals, plugs, wires, etc for a good price?
Irish Pride
Irish Inside
MusicCityUSA
If your plug well gaskets are leaking then the valve cover gaskets will have to be done at the same time. They come in a set.
If i have to buy many things at once i buy from Advanced online.
Use this link to get coupon codes for online ordering. You can order online and pick up at the store nearest you. Advance Auto Coupons
The best one is the spend $100 and get $40 off.
msteiny
Grand Forks,North Dakota
You got the wrong car if you want cheap parts. You can buy most of what your looking for on RockAuto. Valve cover gasket kit, around $70. Seals are around $4 to $5. Plugs and wires depend on what you choose. When was the last 60K done? You might need more than just gaskets and seals. Its best to a lot at one time on these cars.
Irish Pride
Irish Inside
MusicCityUSA
I did a head swap 6 months ago and by using the codes i posted up top i was able to get Valve cover/Plug Well gaskets and 6 new spark plugs for a little over $60.
jimtash
nc
Advance Auto is rocking out some serious coupon deals lately.
