A/C
ckinart
Mississauga, Ontario
not sure if this is the right place to ask this, but... my air conditioning doesn't produce cool air, and hasn't since i got my SHO... is there any way to tell if i just need a recharging, or if i have a compressor problem, etc.?
any tips would be appreciated
thanx
Shoman594
Moderator
Lockport, IL
well one good thing is you have a 94 so your system is R134a. first is your compressor comming on when you turn on the ac ? It can be a few things first you can check to see if your compressor is working. In the front by the radiator look down the left side between the radiator and the altenator, you will see a plug that plugs into a black cylender thing i forgot the name. what you can do is unplug this and there will be 2 connectors. You can put a wire or paperclip between the two connectors. then start the car turn on the ac then check to see if the compressor turns on if it does turn on the system needs recharging or has a leak. or the clutch could be bad
<small>[ February 19, 2002, 11:13 AM: Message edited by: Shoman594 ]</small>
