a/c question...
DavidT
TN
I charged the r12 system in my 91 with "freeze 12". Works great so far. Only thing is, I never see any puddles of water under my car after I park it and the a/c has been running. Is this no big deal, or do I have a problem?
rangerj
Brunswick, Ohio
Check for a plugged up drain. The condensation water is drained via a tube that exits the firewall, thus the water you mentioned. These get plugged and the water usually finds its way into the passenger compartment. Is you passenger side, or center (trans "****") carpet wet?
As for the freeze 12, best wishes. Read the can regarding the contents. If you ever go to an A/C professional have the common courtesy to tell him/her that the Freeze 12 is in your system, so that he/she does not contaminate his/her refrigerant. rangerj
Rob94
Northbridge MA
Forget common courtesy. Tell him so you don't get charged THOUSANDS as "Freeze 12" is crap, will contaminate his supply of R12, and severly **** him off!!
