A/C not working...
SerenityWynd
Fort Worth, Texas
In my husbands SHO, the A/C hasn't been working, it blows out warm air, won't get even a little bit cold, it didn't do this until he had done some work on it, not blaimng him, it's his car. He says it might have something to do with the tensioner? I don't know, he hasn't had time to work on it yet, so I was wondering what might cause this?
Rob94
Northbridge MA
Low refrigerant level, gap on compressor clutch too large, bad cycling switch. The list goes on and on. I'd check the pressure of the refrigerant system with a set of gauges first. If the pressure is fine, then "jump" or bypass the cycling switch and see if the compressor starts. Do these things, then post with results and we can take it from there. Rangerj is VERY good with AC related questions, and I'm sure he'll pipe in with any other things to check.
rangerj
Brunswick, Ohio
The A/C isn't working, but it sounds like there is a chill in the air! Lets see if we can make things a bit more serene!
Thanks for the nice intro Rob.
First, what year are we talking about? If it is pre 94 has it been converted to R134a?
Serenity, do you remember the old joke about "look for the wet spot"? Well, if your A/C is low on refrigerant charge it has a leak. So, look for the wet, oily, black dirt at the A/C hose connections, behind the A/C clutch coil, on the front of the condenser (in front of the radiator), and at the evaporater core connections on the firewall.
You can jumper the low pressure switch to see if the clutch engages. If it does, then either the system is low on refrigerant charge, or the switch is bad.
If you jumper the low pressure switch connection with the Key On Engine Off (KOEO) the clutch coil should become a strong magnet. If it does not, then the coil is bad. If it does, you should see and/or hear the clutch "click" together. If the coil becomes a strong magnet, but the clutch plates do not engage, then the gap is too wide (generally).
The "gap" between the clutch plates should be about .035". If the gap gets too large then the compressor clutch does not want to engage. The gap gets wider with wear.
See the Utah SHO club article about diagnosing A/C electrical problems. It is outstanding. Rob, would you please post the site referrence?
Until we know what is working, and what is not, we cannot be much more help. Do some diagnostics and get back to us.
Lastly, Im going to stay away from the blond jokes. I'm afraid of what might get started! rangerj
SerenityWynd
Fort Worth, Texas
It's Ferendon's SHO, my husband. A red '92 MTX, I can't check on it, he and his car have been at his friend's house for almost a week now working on something else. Everytime I ask how far he's gotten he gets snappy. So I haven't asked, probably get mad if I did right now. Thanks though guys, much appreciated!
