A/C Help
FEARNONE30
Newport, PA
I have a 91 SHO and I want to replace some of the A/C stuff. Are all the components SHO specific or will any taurus stuff work? This has probably been covered but I couldn't find. Thanks for all your help. One mor thing, if I have a 91 SHO, and access to a 95 SLO with a 3.8, would any of these components work to help convert from R-12 to 134A? Thanks.
projectSHO89
SHOless In St L
Several of the refrigerant lines are interchangeable between the SLO and the SHO system. The condensor from the 95 would work in the 91 and would probably help the efficiency of the converted system.
All SHOs from 89-94 use the same Nippon Denso 10P15F compressor, which is not interchangeable with any non-SHO compressor.
When I repaired and converted my 89 last year, I got a reman compressor from AAP, one line from AutoZone, and the accumulator line from Ford. Seals were purchased from AZ.
Steve
