A/C condenser change?
Bob Jusnes
Fuquay Varina, NC
94 ATX 3.2
Hey guys, My A/C condenser has damage which has caused a leak. Im trying to figure out how to remove it. Ive got the bumper and header panel removed to pretty them up a little anyway, so im staring right at the condenser, though I cant figure out how I am supposed to remove it.
It is something simple that I am missing or will this require the radiator to be pulled?
Also, what other things should I be changing while Ive got it apart this far.
Thanks in advance for any advice.
naval-avi8or
Chesapeake, VA
94 ATX 3.2
You have to pull the radiator. Then there are two brackets (next to the radiator brackets) that hold and support the condensor. Of course don't forget all the other associated lines etc that are connected to the radiator and condensor.
SubCool
WappingerFalls
IS there a way to install an electric AC as to not have to use the one attached to the belt system? Or just take the entire system attached to the engine off, and install one under the dash or something?
