A/C Condensar Questions
Jamz SHO 813
Staten Island
I need a new A/C condensor. The belts are very loud and A/C blows hot air. Mechanic says that the bearings are bad. Is there anyway that you could just replace the pulley or do have to replcae the whole unit?
Thanks
SHOtimer
#2910
Santa Clarita, Ca
Well, you were not very specific and rather confusing in your post. The condensor has no bearings in it, it is what is infront of your radiator and acts similar to a radiator except it pulls in heat instead of dispersing it. That only needs to be replaced if it has a hole in it. Your AC blowing hot air could be due to the compressor not turning on which could be because of several different reasons; no refregerant charge, shot compressor, bad switch. Also, it depends on which bearings the mechanic is talking about being bad, if it is within the compressor then yes, the whole thing should be replaced if just within the clutch then no. Hope some of this helped. Also, I just finished restoring my AC system don't be afraid to do it yourself it is really simple and you will save yourself $.
Doug
svtman
Sherwood Park, Alberta
SHOtimer:
What he said - except condensors do act exactly like a radiator and disperse heat. They act to remove the heat which is absorbed by the evaporator during the cooling portion of air conditioning wink
