The only reason i tell them to take it to an A/C shop, is that with the actual high and low side readings we can get a better understanding of what all is going on. Yes, it may be somwhat expensive to go to an A/C shop, but its well worth it. The kits at A-Z (other than the actual gauges) that hook up to one side, are pretty useless, other then them telling you if the pressure is "GREEN"....
Yes you are correct there are certain things that can be done to check the A/C system before heading off to the shop. But when a person that does not know anything about it tries to fix it, they can damage the system.. which would be a high bill down the line.
What im getting at, is with the gauge readings, we can pretty much tell you what the problem is right of the bat. It is much easier to do it this way(may be alittle more expensive) and get it right the first time, then doing it the other way (which could also be MORE expensive.. buying pressure switches, recharge kits, etc..) and taking more time to track down the culprit.
Were both trying do the same thing here. Its just we have different views on the way to get it done.
With no offense to you, I prefer knowing what pressures im working with. Those give you answers to your questions. May take alittle troubleshooting, but IMO its still faster than changing out switches, and recharging a unknown state of charge system, let alone the time to go to the Parts store to pick up the parts/kit.
I see were your coming from though. We
ARE here to help him figure out a way to do things easier, faster, and if at all possible cheaper. Sometimes we need to look past that a do what needs to be done. IMO.
No hard feelings Greg.
Josh.
