bought my 93 ATX about 2 months ago with 92k on the clock....about a week later the AC started cutting in and out. Lo and behold the clutch gap was 16 thousandths out of spec....I regapped it to .030 and was good to go....It has worked fine for the last 3 weeks. Then today, as i was leaving the gas station, I heard a horrible squealing noise (you know, like a freshgirl at a frat house), then the AC cut off.
So i pull over and have a look at the compressor; the rubber coupler on the clutch was shredded. The field coil still pulls the clutch in, but it obviously doesnt turn the compressor. Now, when i regapped the clutch the other week the compressor spun freely, I made sure of it.
Is it like these compressors to just spontaneously seize up (i havent checked yet to see if it is seized or not), or do you think the clutch just finally went?
I would like to think i just need a new clutch as my system still has a full charge of r-12 and no leaks.
Thanks in advance for any comments.
