Markus
I just picked up a new a/c clutch assembly. The two mating surfaces (the pulley and the hub) provide metal-on-metal contact when the clutch is engaged. I am under the impression that one of the surfaces should have a rubber coating on it - the hub I think.
Am I right? Is there supposed to be a rubber mating surface? If there is, what damage may result from using non rubber mating surfaces?
