'99 sho brake problems
JLT1787
SHO-OUT
La Crosse, Wi
I was having problems with the front right caliper, I thought, because it was getting extremely hot and the motor was working against it. I replaced all the calipers, bled them all and everything seemed to be working like it should. I have new rotors, pads and calipers, but the front right caliper is still not releasing like it should. Any ideas?
I have a buddy who works on lots of cars and he said they had a 2000 sable do the same thing and they went and replaced lots of brake components and still could not figure it out. Someone must of had this problem before that knows what is causing this?
Thanks
JLT1787
SHO-OUT
La Crosse, Wi
I agree. After doing more n more research, i'm seeming to believe what I'm dealing with is a brake hose. I'll replace and update. Thanks!
JLT1787
SHO-OUT
La Crosse, Wi
It has been a few days, so finally getting around to respond. Slide pins were grease as the should be, but it WAS the brake hose. I could blow air through the new one, but not the old one. Thanks for everyone's advice.
