Kilty423
Sho-fer
what is require for the upgrade? i have a 93
I dont track my car at all lol. Its a city slut![]()
Ok, I'm looking to do the "96 brake up-grade" in the future as well (when I get another SHO!) and I'm assuming that by "96" we are talking about 96-99 right?(except the brackets-fn74 which are sho specific).
So...
Front Brakes
on a 92-93, I'll need: 94-95 knuckles, 96+ Brakets (fn74 sho), 96+ rotors and pads - only. (keep stock 92-93 calipers)
on a 94-95, I'll need: 96+ Brackets (fn74 sho), 96+ rotos and Pads - only (keep stock 94-95 calipers).
What about the front & rear calipers from the 96-99 models... can they be used as well ? - are they an up-grade or the same as 92-95?
Rear Brakes: what exactly is needed to make the use of 96+ rear brakes for:
92-93 = ?? knuckles, ?? Brackets, 96+ Rotors and Pads (keep stock ??)
94-95 = ?? Knuckles, ?? Brackets, 96+ Rotors and Pads (Keep stock ??)
(outlined as I have above).
and If you would, could you post the the specific parts needed for:
89-91 (as above)
Front: ??
Rear: ??
Recommendation: (street)
Stainless steel lines
Rear Bias Plugs (good and bad)
Performace Friction Pads (Autozone, etc)
Drilled Slotted Rotors (maybe? / looks good)
Others ??
This should help others, like myself, define exactly what is needed for this up-grade in this one thread/post with out any confussion at all. (which I have been, a few times).
... I'll edit as needed.
Thanks!
Do not get these pads. They suck. Hard....I would stick with slotted or solid rotors and some Autozone Performance Friction pads at all 4 corners...
