95mtx c e l comes on only when driving misfires somtimes?
187 SHO
west babylon,ny
check engine lite comes on only when moving,misfires sometimes,then goes back to normal.its kinda strange.i cant get the code our.by the time i get home,&shut it down then key on for the scanner,its gone.
then you are not pulling codes correctly - any cel will result in a stored code that you can retrieve later. check again.
there are 2 sets of codes - the first will be the koeo codes, which may well be 111, repeated twice. then there is a pause and a single flash, then the stored codes are displayed. you are interested in the stored codes.
187 SHO
west babylon,ny
i got them out,187,177,173.i didnt 02 sensors would cause thar much of a problem.i gess i hafta change them.
crystizel
