tommyturbo
Trying to fix this. I've done lots of searching. Cruise stopped working while it was on on the fwy. wouldn't re-engage.
All vac lines look good, including under the dash. Servo looks intact, two halves are still together. No weird vac leak type engine behavior. Checked codes, no codes so vss is probably ok. No airbag lights flashing, and horn works, so believe the clock spring to be ok. Brake light switch works ok. Checked fuse for cruise, it's fine and all the brake light system is on the same circuit and works.
I since swapped steering wheels, and horn and airbag systems are still operational, but still no cruise. So don't think it is a button issue.
What next?
What next?
