95 atx rpm help
DirtySho
indiana
i pulled the codes on my 95 atx and it gave insuficient egr flow, insuficient rpm change and i dont know how to fix the rpm change. does anyone know how i cant fix this? i could realy use the advise.
SHOYAY
WNY
Insufficient rpm change sounds like a bad IAC.
insufficient rpm change during dynamic test is an operator error during the test - you need to goose it harder so that the rpms get over 3000, iirc.
insufficient egr flow is nearly always not due to the egr valve, but due to the sensor tubes being clogged.
DirtySho
indiana
thanks guys for ur help.
ok i got the rpm code problem fixed and i cleaned out all the egr tubes and it still kept thowin the code so i replace the egr, the egr pressure switch, and all the egr tubing and still kept throwin the code any other suggestions. and know it has this strange missfire action. so i pulled all the wires and plugs check them and they where fine. any ideas? thanks for yalls help
