I have a 95 SHO ATX which is no longer starting. The engine and tranny has been swapped and rebuilt with full 60k. For the first two weeks the car was running with no problems. I have also installed a new coil pack and wires.
A couple of days ago, the car was not turning over in park, but would in neutral, but wouldn't start. I checked to see if there was spark and there was. When I poured a bit of gas down the intake the car started. I let it run and then a few minutes later I tried starting it without the gas, but it wouldn't start.
Today, I tried starting the car again, but wouldn't start, even with the gas. I checked to see if there was spark and there was no spark. I wasn't able to find any fuse or wiring problems.
Also, I changed the neutral safety switch. The car was then turning over in park for the first couple times. Then afterwards, it would not longer turn over in park.
I'm confused...anyone able to help?
