SHOOFF13
SHOOFF
Is an mtx limited slip differential the same as an atx limited slip differential? Or do they only fit specific transmissions. I was wondering if you took an lsd out of an mtx and tried to put it into an atx if it would work. I was figuring no probably considering that the transmissions are probably built differently but I am unsure. Can someone help me out and answer this for me?
I might have to consider this then
