I live in Great Falls MT.....Not much in the way of a SHO community here.The timing chains under the valve covers have a "rub strip" the can make a noise like you are describing.
Have someone who already has an automatic SHO listen to it, as they will know the difference.
You will know a lot about the SHO in a short while.
SHO source .....you can bet i will be ordering some parts soon.....:0 as far as i can tell the noise is comeing from underneath the timing belt cover and not from the driver side of the heads where i think the chains are located. The noise is a distintive deep growl with somewhat of a gear type pulse rate. like the teeth side of the belt is hitting some thing when the crank slows down and allows back lash to form in the belt, I heard one on utube and the only comment was 'belt tensioner is bad'. anyone want to jump in here and disagree?
Thanks.
