94 ATX having electrical woes
93SHO24V
MN
So, over the summer my dome lights and my keypad kept draining the battery like within ten minutes of the car not running the battery would be dead ( I think my battery is fried because car cant sit a whole day in the cold without it dieying) I tried to replace the black box in the trunk and im still having the same issues. Also, lastnight I was driving along and all of a sudden my drivers side front window rolled down on its own and wouldnt go back up. I pulled over and opened and closed the door and the window went back up with me pushing the switch. Again, it rolled down on its ow without me pushing the switch. All other windows work just fine and dont share the issue. Anyone else have problems like this on here before me??
deercrusher
never running!
PA
Sounds like you have a circuit in the driver door shorting out and causing a constant battery drain. I'd pull the door panel and look at all of the wires the best you can and check for breaks and shorts.
poffffd
