What did you do about the airbag wiring? i swapped the entire steering column from a 93 into a 92 and the only thing I found different was the airbag wiring. Can I just change the wires from one harness block to the other? I dont want to set the airbag off....
yep just rewire it. i suggest doing this with the battery off. all i did was snip the wires under the dash and install the (mine was a 94) new clockspring with butt connectors very clean and nearly stock.
