yeah the crossover tube has two spots for it for brackets on the front side and back side, both will bolt onto the actual intake manifold
couple things to note
I just have one bracket on mine, the front one, because I couldn't get the other ones to lign up.... also my car never did have that ground strap from the back side bracket bolt that goes to the firewall I believe............ PO must have removed it
the entire engine is grounded though, so you need a few things to check here
the main negative cable off the battery should goto a stud with a nut on the bellhousing or starter area.... mine is a MTX, yours might be slightly different, but same principle
a direct cable from battery to metal part of engine.... now anything that is metal, directly touching that part of metal will be grounded.... this makes the transmission grounded, the engine block, heads, and conesquently works its way to the intake manifold runners...
on my MTX, there are two wires comming off the battery negative terminal... one that goes to the engine, and another smaller one that goes into a ford type connector next to the battery... if u have that make sure it is plugged in... I would assume this goes to the chassis/cabin area to ground it.....
make sure all connections are clean, from battery posts, terminals, cable ends, then look at the part of the cable that attaches to the bolts... it should be shiny, scuff it up, sand it whatever... I take an abrasive pad to mine on my air powered grinder. make sure the bolt that secures the cable on, the face of it where it touches the terminal should be shiny as well.... this promotes good ground transferring....
make sure all bolts/terminals associated with the cable are tight, battery included
everything that is touching and transferring the ground should have good contact, shiny, tight.. metal on metal... this includes the bolts and brackets the hold the crossover tube on..........
I can almost gurantee you something like this, or something missing, is what is causing your problem......... also be certain you didn't do something emberassing... we've all done it.. like forget to plug a connector back on... there aren't any real ingnition related plugs from the intake besides the DIS.... but who knows what you took off so just double check atleast everything ignition related..... I also assume you didn't take off the plug wires? although they are fairly easy to figure out what goes where unless you took them off the coil all at the same time....
