38SHO
#1 Oil Abuser
welp took the car out tonight, first time for me at the drags
93 3.2 MTX, 3.0 cams, 8lb flywheel, 17" volvo wheels, 235-45-17 Pirelli P6 tires, catless equal length y pipe, borla catback
track was VERY slippery, it was like you were on ice or soaked concrete
and I had some bag axle hop going on when the tires spun, I either spun a lot of bogged it
not too happy with the times, but I guess the traps weren't too bad, next time I'll put on some 16's with stickier tires then my 17 all season pirelli's and try to fix the front end bushings up and go for a faster time!
my brother took some video, but once again he said he might not of gotten much.................... so maybe in a few days might have some video of some runs....
1st run spun real hard
R/T: .040
60': 2.937
1/8: 10.541
MPH:72.37
1000': 13.444
1/4: 15.873
MPH: 93.11
2nd run bogged
R/T: .205
60': 2.711
1/8: 10.338
MPH: 72.64
1000': 13.234
1/4: 15.662
MPH: 93.16
3rd run bogged, missed 3rd when sweaty hand slid off shifter
R/T: .209
60': 2.644
1/8: 10.288
MPH: 69.23
1000': 13.291
1/4: 15.774
MPH: 91.41
4th run spun
R/T: .243
60': 2.478
1/8: 9.907
MPH: 72.90
1000': 12.793
1/4: 15.212
MPH: 93.39
5th run, spun, axle hopped so bad it popped out of first gear, thought I broke the diff or an axle at first, when I finally got back into first.. I just rolled on the power again and didn't even have traction on a rolling start
R/T: .700
60': 3.11
1/8: 11.699
MPH: 70.62
1000': 14.661
1/4: 17.126
MPH: 91.90
R/T: .040
60': 2.937
1/8: 10.541
MPH:72.37
1000': 13.444
1/4: 15.873
MPH: 93.11
2nd run bogged
R/T: .205
60': 2.711
1/8: 10.338
MPH: 72.64
1000': 13.234
1/4: 15.662
MPH: 93.16
R/T: .209
60': 2.644
1/8: 10.288
MPH: 69.23
1000': 13.291
1/4: 15.774
MPH: 91.41
4th run spun
R/T: .243
60': 2.478
1/8: 9.907
MPH: 72.90
1000': 12.793
1/4: 15.212
MPH: 93.39
R/T: .700
60': 3.11
1/8: 11.699
MPH: 70.62
1000': 14.661
1/4: 17.126
MPH: 91.90
lower tire pressures. also, instead of dropping the clutch, try slipping it a bit to modulate traction. also, try to avoid going WOT until the clutch is completely let out and you're rolling. with a SHO, smooth inputs with the throttle and clutch are key.
