Blackdr16
93 SHO
Hey all! Anyone know where the "safing" sensor is located at on a 93 SHO? Got airbag code 22 & 24 - suspect either the module or wiring. Not really sure where the sensor is located at. Thanks!
Thanks! I'll check into this!I think I remember a diagram that has the safing sensor behind the driver side kick panel. I don't have my evtm manual anymore but i think a google search will have some successful results. I think 24 might be a monitor fault. You'll have to dig.
Maybe here will help but you have to login to see an answer. Maybe it will let you join? https://www.iatn.net/techhelp/60/2662/1997-ford-aerostar-4.0l-air-bag-light-on
Not sure where the safing sensor is. In the air bag diagnostic module? That is the blue box attached to the extreme right of the dash behind the glove box.
