93 ATX Will not run correctly
JLaughto
About 6 months ago had a complete overhaul, back to factory spec's.
Noticed the car seemed to have problems starting this winter.
Yesterday when starting it hiccupped and has not been acting correct since.
The car will start, but seems to burn oil now(white smoke), rough idle, and the RPM's just sit at zero?
The day before this happened everything was running perfect.
Any Ideas?????
Thanks in advance,,,
Slo-Sho
It wasn't me!
Crossroads, CNY
Your CPS or Crank Position Sensor A.K.A PIP or Profile Ignition P/U is probably in need of attention. As far as the smoke goes.... :shrug: w/o further diagnosis.
JLaughto
Dead
I think I'm done, the garage said no errors codes are displayed.
It's not worth it when odd electronical problems start to pop up.
Engine light is on, it's getting a bad fuel mixture, and is very hard to start.
Maybe something died, it's goit 144k on the car, but ran perfect the day before.
So long for another 93SHO ATX,,,,, :shrug:
JLaughto
Thanks,
It was my CPS or Crank Position Sensor due caused from a newly replaced hose that was leaking,
Thanks for the help,
