93 ATX whine noise when accelerating...power steering pump?
SHObogdan1
Michigan
Hi everyone, for about a month now my 93 ATX makes a constant whining noise that occurs during acceleration. I can still hear the noise at idle but isn't as apparent and I can't figure out where it's coming from exactly. My power steering fluid definitely needed changing so I did that last week. Now, the whine isn't as loud but still there. Do you guys think the power steering pump is going bad? Anyone else have this problem?
SHObogdan1
Michigan
Hmm, the transmission fluid in my car looks good and is at the right level. It shifts smoothly during gear changes so I hope this won't happen to me. In addition the serpentine and timing belts look in good shape.
rbruso
unlikely
Tucson, AZ
Pull the accessory belt and run the motor. If the noise goes away, try turning all the pullies and idlers by hand and see if any of them feel rough.
If the noise doesn't go away you'll have to dig further.
SHObogdan1
Michigan
Yeah, I guess I'll have to get a stethoscope and pinpoint where the noise is coming from. I'm not entirely certain if it's the power-steering pump because it doesn't make an unusual noise when turning around corners or steering. It whines louder as the revs build up. I thought it could be a good possibility because I drove with the whine for a couple of weeks before changing the power steering fluid.
rbruso
unlikely
Tucson, AZ
The ATX is all on one belt. So that is a no-go.
-Sam
I know the ATX only has one belt, and I don't see how that's a no-go. If you pull the accessory belt you can still start and run the car and see if it's anything on the belt line. And with the belt out of the way you can turn all the pullies and idlers by hand.
SHOtimer
#2910
Santa Clarita, Ca
This is what you need to do. Don't run the motor for more than just a few seconds...just long enough to tell if the noise is there or not.
Doug
SHObogdan1
Michigan
Yeah, I'll probably just use a stethoscope because it's just too hard to hear it at idle, only easy to hear past around 3000 rpms
SHOF3AR
Ohio
Same thing is happening to me. Just replaced ps pump and it's quieter but still there. Got a second opinion and they told me its my water pump pulley so I'll b pulling it off a replacing it off my other engine sitting under the tarp :)
SHObogdan1
Michigan
Well I ended up using the stethoscope and it seems like the noise is definitely coming from the power steering pump. So I guess it's now time for a 60K. Thanks again everyone for the ideas!
SHObogdan1
Michigan
Not sure if I have the money to do a full 60k but...in order to replace the power steering pump, does the timing belt have to come off like for the water pump?
TopGunnYFZ
Livonia, MI
Not sure if its the same MTX to ATX but it was a PITA on my MTX with the intake still on. Nothing comes off besides the pump, I do remember having to mess with a motor mount iirc. Find a helper with skinny arms and hands lol.
Your 100% sure its the PS? Sure would be a bummer to go through all that just to have it be an idler.
SHObogdan1
Michigan
Yeah I know what you mean, I made the mistake of driving quite a while with the power steering fluid jet black so I figured that may have caused it. The steering itself is fine, I haven't lost power steering. Hopefully it didn't mess up the rack. I'll check out a junkyard to see if can find a good idler pulley (if I can find a SHO) and I'll replace the serpentine belt. I'll end up taking the intake manifold off too because I have to replace the valve cover gaskets as well.
bmytych
