johnny sho 93
HI, i have a 93 atx and when i bought it a couple weeks ago it idled high at around 1100 rmp instead of the normal 8 to 900 ive had with other sho's ive owned. well it made it from denver to grand junction no problem except for the thermostat sticking closed at vail pass. luckly i bought one in toen and replaced it. and way the car ran great untill last weekend when at my job i flushed out the tranny and put a new gasket and filter on it and on my way home it started to sputter and just lost all sense of power. put the gas all the way to the floor and it wouldnt go above 1200 rps. so i limped it home and i replaced spark plugs and wires and coil pack and still ran the same. i just replaced the cam sensor and still runs the same only idles barely a little higher now but still doesnt like to go above 3000. took it for a spin and the runners wouldnt kick in and just did the exact same as when it first started. have checked fuel pressure which was between 36 and 42 psi. checked for vaccum leaks and nada. need some help guys cause im at my witts end.
