93 3.2 auto xmission low speed servo repair questions
roswell998
Atlanta, Georgia
1. Is there enough clearance to replace low spd servo piston/O-ring without removing xmission?
2. Should O-ring replacement be enough or should piston also be replaced?
3. Any other comments/suggestions on this task will be appreciated.
CheckerSHO
Ford Employee
Acworth, GA
Hello fellow ATL-area SHO owner :cool:
My ATX sho experience is limited but if i remember right...the servos are only a coupla inches from the subframe, and if they are then they wont be able to be removed in the car. Is the servo externally leaking or do you have a transmission shifting concern?
roswell998
Atlanta, Georgia
Answer to CheckerSHO question
There is a little shudder when shifting from 1 to 2. After 105K miles thought rebuild of the servo might help and perhaps wasn't bad preventative maint in any event.
CheckerSHO
Ford Employee
Acworth, GA
Upon further research...that servo is for the low-intermediate band and its on in both 1st and 2nd gear...so it shouldn't affect your 1-2 shift. The 1-2 shift consists of the Intermediate clutch applying, everything else that was on in first gear stays on.
Mr Anonymous
Tire Wall
1-2 shift problems are almost always a result of the stock aluminum forward clutch piston shearing, which cannot be reached without disassembling the tranny.
