92 sho no spark
wicked740
ohio
ok i have a problem with spark. i had it running the other day and it just shut off and i had no more spark. i can start the car without clutch cause its been bypassed i did that in gear car moved 7 feet and had spark agine and then i dident. can sombody tell what all sends the signal for spark besides the cam or crank sensor
itwonder
VA
Search function is your friend as this is a common problem. Ground either lower screw of DIS to battery negative to rule out grounding issue. If still no spark and no codes, probably crank sensor.
