92 sho inside light trouble
wicked740
ohio
I am having issuse with the lights. The only way to get them to shut off is pulling the fuse. I have checked the switch but am clueless of what is going on. It happened to the other sho I had too. Does anybody know what I should do? Thanks for any advice!
wicked740
ohio
Never mind it seems to be the wires to the front drivers door. the botten disconnect for door has corrosion.
wicked740
ohio
Yes, it was the dimmer switch. If I turn the dome lights on they get a little bit briter.i had some broke wires in door harness at dissconect but I just bypassed it. But all that did is fix keypad and the unlock button.
wicked740
ohio
dome light problems
Ok guys I have checked the doors, changed the dimmer switch and they are still on. Is there a modual or something that would make them stay on? The door ajar light goes off so im stuck!
zoomlater
Seattle, WA
Do you have a remote keyless entry? I had the same problem when my alternator overcharged my electrical system. Interior lights wouldn't go off until I unplugged the battery and module. I think I fried my keypad since it no longer works. My lights go off now. If you search for "interior lights", you can get a whole list of possible solutions, unplugging the keyless entry module was one of them.
wicked740
ohio
Thanks for responding. Yes, keypad works untill i have to pull out fuse cause of the lights.
mrecoolgar
SHO NUP
Hershey-PA
Go back to the corroded door switch.
Switch goes bad and will not turn off lights.
Removed and replace.
wicked740
ohio
Thanks guys, it was the driver door switch was corroded and the back pass side door switch was broke. lights shut off now
