92 sho crankshaft p s wiring
wicked740
ohio
Ok i have just put a 3.0 motor in my car. the motor came out of another 92 sho that i wrecked back in november but the wires to the crankshaft position sensor and fuel injectors where cut in the removal there is five wires but i have no idea where they go. i checked all the the conectors for the same color wires but still have nothing. i thought that it was in the main wire harness by the radiator but couldent find anything there either so now im stuck. its hard for me to get around cause i have 8 screws and 2 plates in my back so if anybody could send in the right direction i would really appreciate it.:thankyou:
wicked740
ohio
92 sho crankshaft position sensor help
I found the connector that was cut off that goes to the crankshaft position sensor and i fixed the wires.now i can not find where it hooks up at. Does it connect to the o 2 sensor cause that is the only spot i have left. its the two conectors 1 has three wires and the other dident even look like it was ever hooked up but it has two wires.
wicked740
ohio
92 sho problem solved
it wasent the wiring harness to the crankshalft sensor it was the wires to the 02 sensor. i also had a fuel problem but sovled it also and the car finally run now:woo-hoo
